help
Sorry for the problem. If you uninstall GlassWire, reboot (very important to reboot!), then reinstall our latest version does it solve it? If not please try a second time, but this time after the reboot please install using our “clean” install option.
If it still does not work do you use any unusual security software that blocks drivers from starting?
Thanks The way the problem was resolved:grinning:
