Hello again,
I can’t use the “Apps” and “Traffic” data in the usage tab.
The scrollbar keeps moving on top before I can clic on something behind the first screen. It is annoying.
Cheers,
Whinette
Hello again,
Cheers,
Whinette
Thanks for reporting this. What operating system are you using and may I ask what hardware? If you don’t want to post it publicly you can email us via our “bugs” email https://www.glasswire.com/contact/.
I don’t mind.
I have this problem on windows 7 sp1 x64 running on an i7 860 / 8GB DDR3 / hd7970.
I also have it on windows 8.1 update 1 x64 running on an i5 4300u / 12GB DDR3 / hd4400 + gt730m
edit: both are pro edition.
https://www.glasswire.com/download/ This should be fixed now, please check this update.
Thanks!
Indeed. Thanks for this patch.
