Hi,
Ever since updating to the latest version (v1.2.79) I get these false notifications for Application Info. See the image below.
Do you use any unusual file cleaning or “PC Speed Up” type software on your computer? Can you uninstall GlassWire, reboot, then reinstall our latest version with the “clean” option? I haven’t seen this problem before and we haven’t made any changes to our file monitoring in a long time.
I use CCleaner from time-to-time.
I’ll try doing a clean install, and let you know how it goes.
Thanks!
So far I have not seen the same issue. Looks like it’s good now.
2fast4, Do you still have CCleaner active? If so, then it seems the clean install may have resolved this unusual issue. If it was CCleaner to start.
The reason I ask is that I’m trying to get some time to evaluate CCleaner for my own use. thanks
Hi,
I have not encountered the error since re-installing. I also have not CCleaner since.
