In the latest build i get “attempting connection (1,2,3)” all the time, i can’t log any traffic or see anything that is happening with this problem. could you please fix this or if there is a fix that i don’t know of, please send me in the correct direction. Thanks.
Please go to add/remove programs and uninstall GlassWire, then go to the ProgramData folder and delete the GlassWire folder there, then reboot and reinstall our latest version and let me know if that solves it. Thanks!
Thank you! This solved everything thanks for the fast respons
