Auto Hide Mini Viewer When Hovered By Cursor And Add Option To Settings To Set Font Size, I want to monitor network connections speed in realtime, that should be fantastic!
If you go to our top left menu and choose “settings” there are some options to make our interface larger. Please try it and see if it solves the issue with the font size.
Thanks for your feedback on the rest!
i can’t find the settings your tell me
Just go to the top left GlassWire menu and choose “settings” and you’ll see a “Text Size” option. Move the sliders to make GlassWire’s text size any size you prefer.
