Hi All,
A quick note to software developers of G/W.
I have access to 2 PCs. One running windows 10 the other runs windows 11.
When G/W runs the automatic update under windows 10 it works just fine.
Under windows 11 it gets stuck!
After doing the New Update the open installation window does not close
See screenshot attached.
I checked by running the G/W it was updated and working fine.
The close option on the installation window is greyed out so you can’t use that.
Also, randomly G/W offers’ you an update even though it has been updated,
A bit frustrating as you have to click remind me tomorrow.
Thankfully Windows 11 PC is NOT my main works PC.
There is still a lot I don’t like about windows 11.
But that’s not an issue for here!
Hi all,
I just wanted to update my post.
I uninstalled G/W and downloaded the
Full installation program and installed it into windows 11
version number is in my first post.
It is working like a dream again.
I hope this helps anyone with similar problems…
