Block on Mobile data Only
Before the update I had the option to choose when to block which app
When I am on Wifi I allowed all, but on Mobile it blocked a list.
Now I see that I have to remember to do this Manually every time.
Why is that or is this a bug?
I have an Samsung S9+ with Android 10.
Thank you for your help
https://blog.glasswire.com/2020/03/06/glasswire-3-0-for-android-is-now-live/
“We also found that Google made it impossible for us to block data by WiFi only, or Mobile only with our firewall.”
GlassWire now has profiles, so you can make one profile for mobile and one for WiFi.
https://www.glasswire.com/android-help/#glasswire-firewall
Hi @Ken_GlassWire, would I need to manually switch between a mobile or WiFi profile? Thanks.
Yes, we used to be able to block mobile traffic only, and wifi traffic only, but Google made changes to Android to disable this.
