I tried using the verifier to check for an unusual crash on my pc, however I was caught in a boot loop due to gwdrv.sys , I then went and disable that driver on the verifier but I want to also look at it.
GlassWire crashes are usually due to a database corruption. Go to add/remove programs and uninstall our software, reboot, then reinstall our latest version with a “clean install” option. It should solve the issue.
