Glasswire causes a BSOD on Win 8.1 64bit during or shortly after a successful connect to an OpenVPN provider. TAP driver version 9.21.0, OPenVPN client version 2.3.4-i603.
The error is PAGE_FAULT_IN_NONPAGED_AREA (gwdrv.sys).
Error code: 0x00000050 (0xffffd000205ec49a, 0x0000000000000000, 0xfffff801cc9a94d0, 0x0000000000000000).
Hello I got the BlueScreen on Windows 7 Pro 64bit. After i install the new Beta of GlassWire and reboot the problem still remain. After uninstall of Glasswire I can use OpenVpn again.
Updated to the latest version but itâs also happening to me : while trying to start slickvpn (based on OpenVPN), after the update the process went a bit further (to âadding routesâ) but then BSOD also. Using W8
Hi there,
i have the same problem by using Glasswire with OpenVPN.
Here some information:
GlassWire version 1.0.25b
Windows 7 64bit
OpenVPN version 2.3.4 64bit
I get a bluescreen after i try to establish a connection via openvpn. I closed Glasswire service but i still get the same error.
