Not sure if it’s due to me changing paths in .conf to another drive but I have this setting:
LogDirectory = F:\glasswire/service/log
The “GlassWire Control Service” logs correctly in that folder
But “GlassWire Idle Monitor” logs into F:\20200528.log - it seems that process logs into root ignoring the rest of the path.
I had an issue with upgrade to 2.2.201 and it couldn’t start the service
therefore I ended up uninstalling 2.2.201 and reinstalling it again
The uninstallation process removed all the files and I just edited the new .conf file with the paths.
Just noticed today the file F:\20200528.log
When trying to delete either of those 2 files, Windows reports which process has it open.
The F:\20200528.log is opened by “GlassWire Computer Idle Monitor” (GWIdlMon.exe)
That one only uses drive letter but not the rest of the specified path
I notice that the path you are using for the LogDirectory contains both front slash characters and backslash characters intermingled (i.e., “LogDirectory = F:\glasswire/service/log” ) Maybe your machine allows their interchangeability, but to my way of thinking, all slashes in Windows paths should be backslashes.
