I have Windows 8 in the high-DPI mode. Some parts of Glasswire just look ugly, but some important information (numbers, mostly) are impossible to read.
I hope you get your fix done soon. Glasswire is completely unusable on a Lenovo Yoga 2 Pro laptop. it’s got a 3200x1800 13" screen… which makes everything so small, it’s unreadable!
Just looking for a way to upvote this post. I’m having the same/similar problems with my Dell XPS 15 (3200x1800, 15.6" screen) - Any updates here? I am definitely excited for this update!
I only understand HiDPI scaling superficially, but I know that apps notify the operating system that they are scalable, at which point Windows will not do DPI scaling for the app, as it does with other legacy apps. Can Glasswire not just report to Windows that it’s non-scaling so that Windows (8 and 8.1 at least) will do the scaling automatically? That works for other apps.
Thanks for giving this your attention. I too am using the Yoga 2 Pro and I would like to be able to Glasswire but my eyes aren’t that good.
I recently installed Glasswire on my re-imaged Dell XPS (high DPI machine) and my latest experience has been that the pop-ups are legible and the UI looks like it is using pixel doubling so things look like they are actually working. Your mileage may vary but this is my current experience with Glasswire
Maxpower720, you are absolutely correct! I just tried the 1.0.30 beta and pixel doubling is working! Native HiDPI support would be even better, considering how beautiful GlassWire is, but scaling is fine and lets me read the dialogs finally.
The program is very good. Knowledge is the best in its class.
However, the letters can not be read because They are very, very small. Please increase this significantly. I have got Windows 7 64-bit operating system I use 150% with DPI and Dell 2408WFP Monitor 1920x1200 resolution, but it does not change anything. Micrometers all of the letters, which is very small, unreadable.
Our 2.0 software will offer high DPI support, but it’s not some super easy thing unfortunately. We have to recreate all these UI parts in all different sizes and it’s very difficult. The update should be out before the year is out and I apologize for the delay.
There are some other threads about font sizes here where we have posted the status recently.
