Can I monitor just one connection?
Hi all,
I use the same laptop at home and in the office. Only my home connection has a monthly limit on the data that I can use.
Can I set up GlassWire so that only data used while connected to my home network is used?
Thanks!
@Swordfish742
Thanks for your feedback on a feature where GlassWire separates its monitoring per WiFi network. We can’t currently do that unfortunately.
It’s 250 Gb.
I could turn GlassWire on and off depending on where I was, but that is a little annoying and I am likely to forget!
