Hi,
I was just wondering if Glasswire is able to report on the traffic that is originating from my Virtual Machines as well.
They are NATted/Bridged to the same NIC on the Host machine.
Hi,
It depends on the virtual machine type, but yes it should work in most cases. Please try and let me know your results.
You can also consider just running GlassWire inside the VM itself.
