Would it be possible to add a click through option to the mini viewer so its possible to click things behind the mini viewer when its on top.
The setting could reset when the mini viewer is hidden to allow people to undo the option.
Thanks
Thanks
Some others have asked for this and gave an example application that accomplishes this task. Initially we thought it was impossible but it appears it is not. We’re investigating if it could work with the way we build our software. Thanks for your feedback.
