First, it’d be nice to be able to sort columns. But that’s just convenience. What’s more important: go to e.g. Usage > Apps and select a process. Notice how when the Apps list updates, the current selection does not move with the previously selected App? Thus I now see something completely different and at every list update I have to hunt down the previous app again…
Micha,
Thanks for your feedback. We’ll work to improve GlassWire via column sorting and usage usability.
The Firewall has a list of applications accessing the network also so if you lose it under “usage” sometimes you can find it there if you choose the time period correctly at the bottom of the graph.
Thanks!
Any update on the column sorting? Would be nice to be able to sort, so the most bandwidth hungry apps would be on top for example.
