Bug Report!
It’s been happening for the last few versions. Windows 10 Pro x64 Build 1803 and I also had the same issue with Build 1709 of Windows. The thing is the file doesn’t change on every reboot.
TIA,
Daniel
Bug Report!
TIA,
Daniel
I just messaged you a new version of GlassWire to test. Another customer had a similar issue and we’re seeing if that update solves it.
Please check and let me know your results in the private message.
I have noticed that as well, but have been ignoring it.
Same here for awhile then I decided to say something! Hopefully they will get it sorted.
I’m experiencing the same issue. Every single boot these 5 entries appear.
I am running Windows 10 Pro 64bit version 1803 (OS Build 17134.81)
We think we found the problem and we put out a fix in our next update. Thanks for all your reports and help.
