Just bought Glasswire and while I love it, I’m close to trashing it. The reason is that I have a constantly high CPU usage of around 30% to 50%. My t460s churns on the fan for minutes on end.
This is with the official download from the website. I read to use a glasswire.cond file with “enable_network_scan = false” but that didn’t help much. I also disabled monitoring of webcam and mic.
I use this mode also with no high CPU problems. If you go to “Click to block” does it make any difference?
If you do a “clean” install of our latest version does it help? After uninstalling GlassWire go to the “Windows Firewall” control panel and click “restore defaults” then try doing a clean install if you don’t mind.
I am guessing you double checked the Task Manager and you’re sure it’s GlassWire causing this high CPU usage? Is there anything else unusual about your network or the software on your PC?
Not overly helpful but it sounds like cpu thrashing. Any chance glasswire or firewall are mid-privileged?
I know it makes no sense but I am as well a dev and I’ve seen this issue in ms office. Where an extension runs code with the wrong permissions.
