Yesterday evening I watched an hour of streaming video from Amazon . Immediately following that, my GW Graph window showed no data usage for that hour. However, today I can see where there is now displayed data usage for that time period yesterday. It seems like the data usage did not appear until after I had shut down the computer overnight and restarted this morning. Is this “delayed display” an expected behavior? I think I have noticed it previously as well. Thanks for the help.
I’ve noticed several tabs don’t update in incognito.
[Usage] is always zero, for example.
Also, on the graph one can see traffic while incognito, but clicking on a peak does not display the active application (as it should).
If you drop incognito for a second or two, then reinstate it, that seems sometime to trigger updating.
Dropping incognito wipes the graph, though, so one still cannot find responsible apps.
Thanks for the replies. I do not use incognito mode at all. Since I first wrote about this, I have watched other streaming video and have not seen the delayed usage issue again. I am thinking it might be due to a data refresh action that is triggered by a specific event that occasionally I must inadvertently skip. Since I have not been able to reliably replicate the issue, I can’t test it.
