alr so basically i turned on the firewall option, so i had to accept connections coming into my wifi, my pc wire cut out and i pluged it back in, now my pc says its connected to the internet but it says there is no connectivity so i cant sign in to do my stuff, so im locked out of the desktop. help please
Sorry for the issue.
We use the Windows Firewall API built into Windows itself for blocking, so it’s easy to fix any issues.
- Go to add/remove programs and uninstall GlassWire
- Go to the Windows Firewall control panel and choose “restore defaults”.
- Reboot - IMPORTANT
If the issue still exists it’s unrelated to GlassWire.
Make sure your phone is accessing the network. If you have Android’s “Data Saver” option in the Android settings switched on be sure to white list GlassWire there. Does it still not work? Consider rebooting your phone and reinstalling GlassWire by accepting all required permissions.
Regards,
Peter
