Hello - I am evaluating Glasswire and so far it looks good. WE have a legacy windows application called Phoneslips that is a peer to peer messaging/scheduler system. It doesn’t seem to list the publisher or listed under unsigned. I cant find it on any app list or showing data sent.
I was wondering if Glasswire doesn’t pick up all applications running.
GlassWire should pick up all applications that have network activity. We use a Windows API for network monitoring created by Microsoft so it would be quite strange if it didn’t pick up something.
If you reboot your PC then use that app does it show up? We warn that when GlassWire is installed you should reboot to make sure you don’t miss any currently happening network activity, but we don’t force a reboot.
Some legacy apps also use IE to send their data because they are actually just kind of an IE shell. Maybe it’s something like that?
