Not starting after reboots on Windows 10 Home.If you want me to run Farbar let me know.
Is “Run on startup” checked in your settings? Do you use any third party apps that block others from starting?
If you reinstall GlassWire using our “clean” option, then reboot, does that solve it?
Clean install fixed it,Thanks.
