i used glasswire not for long, i loved it but i have one complaint, sometimes i really get confused of how many internal and external traffic an application uses as people may get confused that all that data is to/from the internet, instead there may be a portion to another computer or the router for example, if you guys can split the graphs up or even put in an internal and external collum of usage that would be great
If you click on the Usage tab, you will see in the upper right corner of the left side “All Usage” panel, a dropdown list labled “Options” . You will find the controls for Internal/External there.
