The subject line here says it all!
Reason:
One serious disadvantage of using Windows Firewall is that, unlike most genuine third-party firewalls, it does not suspend a program when an alert dialog is displayed, but only blocks its connection attempt. I find this commonly very disruptive, because it causes program glitches and even failures / crashes - most of all when I’m installing a program and the installer tries to connect online, usually for quite legitimate and indeed often essential purposes. I wish GW could suspend programs when an alert is displayed, but to my understanding that would be impossible as the problem behaviour is simply a primitive and very unhelpful aspect of WF itself.
So, I came to realize that I could work round such problems by temporarily switching GW from ‘Ask to Connect’ to ‘Click to Block’ immediately before doing an installation or other action where expected GW prompts could be disruptive. The trouble then, however, is that it’s just so easy to forget to switch back to ‘Ask to Connect’.
For this reason I really do earnestly want the option of a tray warning to be showing while ‘Click to Block’ is operative, to help remind me to switch back to the much more secure policy. Also, an option to ensure that GW always starts up in Ask to Connect mode if its mode at last shutdown was Click to Block. – Thank you.
