I see a lot of previous threads on same request, and you mentioned that this feature is in the works. But I haven’t seen updates since. Any update?
Any example (using DU Meter)
Thanks for your feedback. Please note if you go to our top left menu we have a “mini viewer” that is also helpful, in case you did not know.
