is there a solution about this ? or there isn’t a major problem about this issue ?
Kaspersky disabled the Windows firewall. We recommend using another antivirus that does not disable the Windows firewall.
kaspersky is my protection suite i have right now and i have paid for it, glasswire isn’t a solid security app,right ? so for now i leave it as is , is there a way to bypass the deactivation ?
I think Kaspersky has an option that doesn’t disable your Windows firewall, but I’m not 100% sure what that product is called.
