I’ve been using the free version of Glasswire for a while now (past year or so) but have finally decided to get the paid version.
While using the free version I did not use the built in firewall for Glasswire (mainly used it to track bandwidth usage) but now I am planning to use the firewall feature.
My problem is the firewall page is full of a massive list of stuff that seemingly has no easy way to look through, sort/filter/search or manage in any meaningful way. You can’t even see details for a given program in the firewall list unless it’s actively communicating at that moment. There seem to be some basic features/functionality that seems to be missing from the firewall section of this program.
Is there a way mass remove all entries from the Firewall list so I can basically start over without clearing everything else (the bandwidth history, etc…)??
EDIT: I decided to just to a clean install and deal with it.
Have to say though, the FireWall UI is missing a lot of stuff that I think it needs.
Where is the ability to sort entries? Why can I not group entries together? All the “Adobe” programs should be in their own group, “Microsoft” in theirs, etc… Would make organization a lot easier and mean I don’t have to scroll through pages and pages of entries that seem to have no apparent order.
