I’ve been using version .28b flawlessly. Now that I updated to .30b a few seconds after opening GlassWire it stops working and says that the service stopped running. When I force the service ON I get a BSOD “KERNEL SECURITY CHECK FAILURE”. After that every time windows boots it BOSD until I disable GlassWire service.
Windows 8.0 (up-to-date patched)
Thank you for reporting this. I’ll report the problem to the team so we can figure it out and fix it.
Please email us a crash dump that can be found at C:\Windows\Minidump. Our contact email for “bugs” is here: https://www.glasswire.com/contact/
I got some good news and bad news.
I opened GlassWire again to crash my PC because I cleaned the old minidump I had.
Windows kept switching the glasswire service off, so by forcing it on I got a BSOD within a minute.
problem is earlier today I had set paging file to 0. so no dump was created. facepalm
When my windows restarted it installed a few updates that now prevent glasswire service from auto-switching off. Instead the service stays ON and the glasswire app crashes. (I’ve been going at it for 3 hours now, I can’t get a BSOD anymore)
If I mange to get one I’ll send it straight to bug report.
