This is on a brand new PC (z690, 12700K, 32Gb, Mellanox 10Gb controller on PCIe 3.0 4x)
My previous PC had limited PCIe bandwidth so i don’t entirely blame you for making me buy a new rig
Anyways, do you guys know if we can disable everything but firewall? Since you’re hooked up to windows firewall, i figure it’s not the culprit. Other stuff like bandwidth monitor are more likely to be blamed?
Follow up: I did further tuning to reach 9.5 Gbps without Glasswire, and now with your new build I get 6.5 Gbps. So i think your latest optimizations did add a few gigs ! I’ll live with 6.5Gbps, thanks
I found this thread because I have the same problem. Out of 10Gbit, only about 1.5 to 2 Gbit go through when the Glasswire service is running. If this is stopped, I get the full 10Gbit.
The following versions of Glasswire were tested: 2.3.449 & 3.0.482
Test environment: Current Proxmox Hypervisor, current Windows 10 22H2, VirtIO Driver Version 0.1.225
