windows 8.1
On a computer worth 360 total security antivirus and firewall glass wire.
A few days like something was blocking access to the Internet for the glass wire.
Disabled windows firewall. Did not help. Virus on your computer does not. The remaining applications are running perfectly. Sites open all. I tried to remove glass wire and place again. Does not help.
What to do?
Try removing GlassWire again, then go to your “programdata” folder, then delete the “GlassWire” folder there, then install a second time and let me know your results.
That helped! Thank you!
