Well, I checked services and restarted my computer and It didn’t fix the problem. So I uninstalled Steam version and clean installed with the installer from this website, it seems to be fixed. I’ll ask further more if I get any trouble more. Thank you for the reply.
I’m glad GlassWire is working now! One thing about Steam is that some people will install GlassWire from GlassWire.com and the Steam version simultaneously and GlassWire can’t work that way.
In case any Steam customers ever read this in the future the best way to solve this is to:
Uninstall GlassWire in Steam and in add/remove programs on Windows (both places!). Now reboot your PC (very important step!).
Now decide if you want GlassWire for Steam or our latest version from GlassWire.com. Steam codes are compatible with both versions. Now install GlassWire using the “clean install” option in our installer. If you don’t use our “clean install” option GlassWire may not work and you’ll have to start the process over.
