GlassWire idle monitor has stopped working v.1.2.73
I am using Win 10, GlassWire version 1.2.73. Every couple minutes I get a windows alert that “GlassWire idle monitor has stopped working, windows looking for a solution”. It’s starting to get really annoying. Uninstalled, reinstalled…keeps happening…
Please try one more time uninstalling, but this time reboot, then reinstall using the “clean” option in the installer.
Do you use Asus hardware or Nahimic software? If so before reinstalling GlassWire update your drivers please.
I will try that when I get home from work. I don’t use Nahimic software but motherboard and soundcard are both Asus.
