Sorry for the issue! I can say that the Android and Windows apps don’t interact in any way.
To access the GlassWire settings go to the top left “GlassWire” menu and choose “Settings”. You are now under the “General” tab in the settings.
The “Begin idle mode” allows you to choose if GlassWire will detect if your computer is idle or not and show that info on the graph. Showing your computer is idle on the graph is useful because if you notice strange network activity while you were idle then you will probably want to investigate what happened during that time period.
“Run on startup” makes GlassWire start when you start up your computer.
“Enable tray notifications” allows tray alerts to temporarily appear on your computer desktop and alert you to possible problems. If you only need to disable these notifications temporarily you can go to the top left GlassWire menu in the main window and choose “snooze alerts”.
“Send GlassWire Alerts to Windows Event Log” duplicates alerts to you Windows logs.
“Enable admin account password request” keeps GlassWire more secure by only allowing changes to GlassWire if you have your admin password. Otherwise anyone who has access to your computer could easily change your GlassWire settings any time.
“Use system time format” to allow GlassWire to follow the time format specified in your system settings, otherwise it will follow the language settings.
“Look up DNS names for hosts (nslookup)” resolves DNS names via Nslookup.
“Bandwidth Speed Units” allows you to choose bytes or bits per second.
“Clear history” lets you to easily delete your graph history. We never have access to your graph history and your graph history is only stored locally on your computer.
This may help you,
Rachel Gomez
While the OP is a little old I can confirm this has not been resolved. Every version I have of Glasswire randomly resets its config file. In the end I got so sick of it that I just decided to backup the client.conf file on my PC so I had a quick recovery option. Stop service, Exit GUI, restore original client.conf file overwriting the reset version, restart service and GUI. Back to normal.
Currently running 3.3.504 and this still happens regularly. Wish the devs would take a good look at why this is happening.
Can confirm. The issue hasn’t been resolved yet.
Add to that the Network Scanner Auto Scan turns off after every restart.
Hi @Lennon ,
Please can you confirm that you are not installing with “Clean install” enabled? If not, please can you send logs so that our engineers can investigate? These can be sent to help@glasswire.com
Thanks,
Katie
Hi @Katie_GlassWire, I can confirm that I am not installing with a Clean install. This just occurs randomly without any install at all. I can only assume that in some instances it may be happening as part of automatic update, but otherwise I am not reinstalling the software manually. One day my config is there and the next it has been reset.
When it next occurs, I will send the logs but it is unpredictable and might take some time.
Ensure that you are using the latest version of GlassWire. Developers often release updates to address bugs and improve software stability. Visit the official GlassWire website or check for updates within the application. Right-click on the GlassWire executable or shortcut and choose “Run as Administrator.” This ensures that the program has the necessary permissions to save and retain settings.
