My GlassWire instance keeps losing its activation. I keep re-entering the product key and it’s getting a bit annoying. The version of the GlassWire is 2.1.158 and running on Windows 10 OS.
Do you use a “cleaning” type of application? If so can you white list the programdata/glasswire folder and see if that helps?
If you don’t use that type of app can you uninstall GlassWire, reboot, then reinstall with our “clean” option? Perhaps somehow our files were corrupted.
