First of all please re-enable Windows Firewall. That has nothing to do with our software installer and it could not cause an issue with installing our app.
Double click the installer and do nothing else, then wait. Please look at the taskbar for any notices that you need to click. Please wait at least 2-3 minutes just in case.
If you don’t see the installer window after trying this please let me know what other security apps you are using. I see you mentioned ExpressVPN. Is there anything else installed, or any other firewalls?
Answer to your questions:
I saw I had a old installer & I downloaded the latest version. Same issue. Deleted installer rebooting now.
Yes I have Express VPN.
I just installed it again don’t see it after install now rebooting.
Restarted nothing no Glasswire installed.
I thought there could be something in my event logs but I see nothing just a empty glasswire folder.
@Justin_Strack Could you please send me some logs to help me fix this?
Run cmd.exe as admin
Move to the GlassWire installer folder
Run the GlassWire installer with the /ENABLE_LOG parameter.
Finish the installation and send us the install.log file that will appear on the desktop.
You can click on my name here to send it to me, or email it to us. Please include a link in the email to this forum post so I know what the logs are for.
When I installed 21h1 I think it didn’t allow me to keep anything so it wiped it out.
HP changed how they do restores on there computers you basically have to know how to do it yourself. I used Macrium Reflect to clone my SSD. Then wiped it with the new install in windows.
No, HP still uses a recovery image/partition that has their preloaded OEM bloat on it.
I’d recommend getting the Media Creation Tool from Microsoft and using a USB to create installation media. Then use that to delete all partitions and proceed with letting Windows create it all for you. It will be a base Windows 10 install with no OEM preloaded bloat.
Yes, I’m tired of trying. @Tarun I had problems installing Bulk Crap Uninstaller all kinds of .dll problems. Virtual Run time problems with the application.
There’s also a portable version. It honestly sounds like you have problems with your installation and a reinstall would be the best bet. See the segment I mentioned about using the Media Creation Tool.
