Is there a way to keep GlassWire always on top (always in the foreground)?
My op system: Windows 8.1 Pro.
Thats funny I have Win 7 Pro and I have the opposite effect . GW is always on top I have to click the other program showing to get it on top of GW. I know Win 8 has a different approach due to the tiles having priority over other non-MS apps.
We’re working on adding a simple desktop viewer. Currently there is no way via GlassWire itself to keep it on top but there are third party utilities that can do so.
Hi Duncan,
Thanks for your quick answers.
I use Always-On-Top from labnol.org since years - it works fine, but not (Not!) with GlassWire (:-((
Regards Pete
I have to correct this: Always-On-Top works also with GlassWire.
I don´t know what happened - I tried and found AOT not working with GW immediately after installation of GW. Now (after a couple of other operations with rebooting Windows) it works and GW stays in the foreground.
Pete
By the way - GW shows an alert that it had changed application version from “1.0.38.836” to “1.0.40.850”.
Did this cause different behaviour of Always-On-Top?
No. GlassWire alerts if its version changes, this is normal.
