Glasswire safety score / Process tracking
Hello!
So far I think that this is an amazing piece of software you guys have developed. I just had a quick question about the “safety score”.
When it says X amount out of 30,000+ ClearGlass users have used ____ app in the past month. Is it referring to binaries with that name? Or is it digging deeper and categorizing it by specific hash, or file path, executablepath etc…
Hi @bjzilly,
We consider two apps to be equal if they have the same filename and publisher.
Best,
Katie
Where is the data for the “Safety Score” pulled from? Home user + business or only home users?
Hi Geri,
There is no definition of home or business endpoints, the data is processed from all endpoints which have data processing permissions enabled.
Best,
Katie
Good to know. Thanks for the fast reply.
