Glasswire Security - remote access & virus total are not staying on after checked. When I go back into settings they are off.
I have not heard of this issue. Sorry for the problem. If you uninstall our app, restart your PC, then reinstall with “clean install” checked does it solve it?
Do you use any “cleaning” or “speed up” software? Maybe it’s deleting our files?
