Glasswire stop after I turn on my pc.
my windows firewall stop after 2 mins. but in windows security center firewall on and the icon has red cross(task view)
How do i fix this issue. it start from last few days.
Thanks
Thanks
Do you use any other security software? If so what is it? Maybe it disabled our app?
Could you try our latest software?
GlassWire for Windows has a local Windows service that runs locally on your PC. This Windows service keeps track of your network activity for your PC or server. If that Windows service cannot start then GlassWire cannot graph your data usage.
Please note your graph data never leaves your PC, and we at GlassWire cannot ever access that data since it’s only stored locally on your own PC or server. Our privacy policy explains how we can’t ever see your data.
If you are experiencing this problem first try rebooting your PC. If GlassWire still cannot run please uninstall GlassWire in add/remove programs, then reboot your PC (this is an important step in the process), then reinstall GlassWire while checking its “clean install” option in its installer. You can download our latest software from our download page.
If GlassWire’s graph will still not load please check to see if the following Windows services are running in the Windows task manager:
These Windows services are usually on by default unless you disabled them. If you find these services are running but GlassWire will still not run please consider running Windows Update. With very old versions of Windows GlassWire may not run properly. After updating your device please once again try a clean install with GlassWire in the order listed above.
