I have uninstalled and reinstalled. I have rebooted. Have deactivate subscription and reactivate subscription. Can’t seem to get “ask to connect” to work.
As long as “ask to connect” is activated, anything else besides those already in the rules will get blocked and no notification at all when there is new connection. The only way for me to allow new apps to connect is to change to “click to block” mode and then switch back to “ask to connect”
Still then I can’t get “ask to connect” notification to work.
I only have malwarebyte free version installed. So no firewall and no active running anti virus.
Would it be possible to email me with a link to this thread? We can then provide a logging version of GlassWire Monday that will help us find/fix this issue.
I just wanted to play Guild wars 2 again. Got a popup for the guild wars2.exe but for the second exe (CoherentUI_Host.exe) they use for the in game shop there was no popup at all.
And since I instantly tabbed out after opening the shop to click any appearing popup to allow it I can say for sure there was none.
It wasn’t even listed under alerts or under blocked. Other stuff so far was working ok, gw2 not.
From the windows firewall log maybe it could help:
Fresh install , add activation key , move firewall to on and “ask to connect”.
All traffic from new apps is halted, no popups are created for new apps and for auth.
I personally use “Ask to connect” all the time, and I cannot recreate this. But yes, it’s good it’s so easy to recreate on your PC because it will help us solve it. Thanks for emailing!
I am now waiting to hear back from my team on next steps.
I’m also having this issue,
However I can report on my desktop using Glasswire v2.1.167 this issue is not present,
I’m seeing this issue on a new computer I installed using Glasswire v2.2.201
Please let me know how I can send logs as well to help you guys troubleshoot
Please switch logs on, recreate this issue, then send us logs.
Stop the GlassWire service with the task manager under “services”.
Open the file: C:\ProgramData\GlassWire\service\glasswire.conf as administrator.
Set parameter LogEnabled to true and save changes.
Start the GlassWire service.
Please start a few apps that need network access and get no prompt, then send us the logs from C:\ProgramData\GlassWire\service\log as soon as the issue is reproduced.
Maybe the email was filtered somehow. I just sent you the file via a private message in the forum itself. Look at the top right in the forum and you should see my message with the Dropbox download link.
