When I start Glasswire it attempts to connect, but after the 3rd connection it displays:
The Glasswire service stopped running
(Restart Glasswire)
Clicking on restart cause the application to go through the same sequence. Glasswire was running in Windows 7 before upgrading to Windows 10.
Any suggestions on how to fix this would be appreciated.
Please uninstall GlassWire, go to the ProgramData folder and delete the GlassWire folder, reboot then reinstall our latest version. Thanks!
That fixed it - thank you.
this is funny. with me occurred the oposite: I had the same issue, I uninstalled GW and reinstalled again, and the problem persisted. only with the upgrade from windows 7 to 10 pro and installing again solved my problem
