Hi GW,
Annoyingly, some days it starts, some days it does not start. I want to permanently fix this by running a startup script from Task Scheduler. All I need are the command line parameters that start and connect GW.
Unfortunately, neither of these commands work to start GW once it has loaded but is still not running:
- “C:\Program Files (x86)\GlassWire\GWCtlSrv.exe”
- “C:\Program Files (x86)\GlassWire\GlassWire.exe”
I would also add that this problem has cropped up fairly recently (maybe with the most recent [2.0.91] update). The GW service shows as “started” in the Services GUI at these times. So, how can I force GW to connect to the service using the command line, so I can automate the process, at least until this startup issue is resolved?
Thank you.
dfg
