On my GlassWire instance I never get update alert. For example my version of GW is 2.3.397 and latest is 2.3.413. I already reinstalled/restarted of GW and it still not inform me about latest updates. Any hints?
Hi, on my [Windows] â [Settings] â [Notifications & actions] I donât have any GW setup or switch. Maybe I looking on wrong place in Windows settings. Any hints? Thanks!
Windows notifications donât matter. When this worked it was the program itself issuing the update notification. I donât recall that it sent anything to the notification area.
⢠GlassWire > Settings > General > Enable tray notifications
⢠Windows > Settings > System > Notifications & actions
FYI: these two are completely different animals. A software developer can use either or both.
To the best of my recollection, GW never hooked into the Windowsâ.
An auto-update feature was added to GW in v2.3.363 (10/25/21) and in the latest v2.3.413 (05/24/22), âFixed an issue where auto-updates can sometimes fail.â
I believe I remember auto-update just ran whether one wanted it or not by displaying a modal window having âinstall nowâ or âlaterâ options. This was changed in v2.3.374 (12/09/21), âAuto-update improvements and fixes, as requested by users.â
Iâve always just downloaded the latest GlassWireSetup.exe and run over the previous and will continue to do so.
But to save my life, I canât find anywhere in GW Settings where one manages the auto-update feature. I must have disabled it somehow, sometime. So, no method to re-enable it??
