gwdrv.sys Occurs when using a network agent Bluescreen code:DPC_WATCHDOG_VIOLATION (133)
The blue screen occurs after the network proxy is turned on for a period of time, which occurs occasionally, and is common when the network load is high.
Related windows debugging information:
SYMBOL_NAME: gwdrv+424e
MODULE_NAME: gwdrv
IMAGE_NAME: gwdrv.sys
STACK_COMMAND: .thread ; .cxr ; kb
BUCKET_ID_FUNC_OFFSET: 424e
FAILURE_BUCKET_ID: 0x133_DPC_gwdrv!unknown_function
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {229a5753-87e5-3d87-e2b9-50836a10c652}
Followup: MachineOwner
BUGCHECK_CODE: 133
BUGCHECK_P1: 0
BUGCHECK_P2: 501
BUGCHECK_P3: 500
BUGCHECK_P4: fffff800260fb320
DPC_TIMEOUT_TYPE: SINGLE_DPC_TIMEOUT_EXCEEDED
@RainThings
Sorry for the issue.
  1. Please update to our latest version. Download Firewall Software by GlassWire
Did the issue continue?
  1. Please go to add/remove programs and uninstall GlassWire, reboot, then reinstall with our “clean install” box checked.
The most common reason GlassWire crashes happen are a database corruption.
Did the issue still continue? If so, do you see a .dmp file on your desktop? If so please email it to us with a link to this thread. The file may be quite large, so please use a cloud service like Google Drive to send it. Contact GlassWire .dmp files allow us to analyze what has happened in detail, then put out a fix for everyone.
If you don’t see a .dmp file on your desktop then it may not be GlassWire crashing.
