Hasn't Connected for 3 Days v 3.10.1138
I have Premium and just out of the blue 3 days ago it stopped connecting.
I’m on version 3.10.1138.
Says “Connecting to the Local Server.” Never makes it through and I can’t go to Settings due to it being greyed out.
I uninstalled, did ipconfig /flushdns, /release, /renew, netsh winsock reset, netsh int ip reset. Made sure to do a complete clean reinstall and directly specified allowing the program through windows firewall.
Still the same result, it doesn’t work at all unfortunately and I’m all out of ideas of how to fix it. I would appreciate any help that guides me to the fix.
Hi you might have to send a log file them so they can take a look to see what the issue is
This will show you what to do in this post below
You could have a look at this post as well, might have something else to try
I had to stop Windows Event Log and Event Collector and direct the log and get it going. Seems even though GlassWire Control Service was set to Automatic in services.msc … it wasn’t running and doing all that combined and getting event log running again, it’s all up and running smoothly finally.
Solved for now.
