How do I block a single inbound network intrusion. I don’t want to block all of them and do not see the option to block at all anymore.
Instructions for Windows are here.
https://www.glasswire.com/userguide/#Firewall_Tab
Android is here.
https://www.glasswire.com/android-help/#glasswire-firewall
Go to the firewall screen, then tap on the app you want to block. Make sure our firewall is switched to “On” or it won’t block.
Thanks ken,
I appreciate your assistance…!
Have a Great rest of your week buddy.
- Mike -
