I am using Glasswire 1.2.71b. Free version. Very nice program. But it does not load in the systray of Windows 10 until I open the program once after bootup. Then it remains there until another reboot. Is there some way to get it into the systray on bootup like 360 Total Security does?
Thanks,
Dave
@DBarker49 GlassWire should load by default, unless you disabled it or another application did. Go to the top left GlassWire menu and choose “settings” then make sure “run on startup” is checked.
Seems like that was the problem. It was unchecked by, default, I think. I checked the box, so it should be fine. Thanks very much.
Dave
