I just switched from the free to the paid version and would like to start my connections through Glasswire from ground zero. Is there a way to easily zero out all the connections and then select “Ask to connect” option for each?
Thanks for the assistance.
Update: I may have found the answer in another post.
- stop the GlassWire service
- remove the database (c:\programdata\glasswire\service\glasswire.db)
- start the GlassWire service
This seemed to do the trick
