This crash was about an hour ago.
Does anybody want this dump?
Please email it using a cloud service like Google Drive.
Thanks for your report. Some solutions:
Unfortunately this usually happens if your database is somehow corrupted. A clean install will fix it if that’s the case. How to back up data and settings.
If you’re using an older Windows version, please run Windows update.
Unfortunately, I DID a clean install…
Interestingly enough, the crashes have stopped happening.
I configured the service to automatically restart two times after which it crashed three more times (putting three more memory dumps on my desktop.)
Then it all stopped failing. I have no obvious explanation but I do keep my system updated.
I am using the presence of a crash-dump on my desktop to determine if it fails.
I’m glad everything is working now. I apologize for the issue.
Maybe it was a conflict with another app?
