I just get this error right after clicking on the setup file:
"GlassWire 1.0.30 setup | Installation failure!"
OS: Win7 x64
Perhaps the installer was corrupted. Please try deleting and re-downloading.
The installer seems to be ok because I can use the same installer successfully on another system. But on my Win7 HP x64 it fails (although I’ve downloaded the installer several times). Maybe there is a compatibility problem with Microsoft Security Essentials?
OS:Win7 Home premium x64 - installed latest Microsoft updates + Microsoft security essentials --> Glasswire installation fails!
OS: Win7 Ultimate x64 SP1 - No Windows updates are installed; no MSE installed --> Glasswire installation successful!
I am 99% sure there is no compatibility problem with Microsoft Security Essentials. We will try to recreate this on our end, meanwhile if you figure it out please let us know.
Nope it’s not MSE. It still fails having MSE uninstalled.
But as I said there’s no major difference in systems settings and installed apps on my two computers other than mentioned in previous post. No idea what could have caused the problem
@Servo_GlassWire, Maybe you guys should add a logger into the installer, so users can upload their log files. IMO debugging on your end would be a lot easier in that case.
Good idea. I will ask if it’s possible to add installer logging or maybe there already is some. I have never seen an install failure before.
"GlasswireVersion 1.0.35 beta setup | Installation failure!"
OS: Win7 x86
The installation failure here (Win7-32) appears to be caused by the failure of the Glasswire Service to start during install. When attempting to start the service via the service manager, there is a message that states that the service started but immediately stopped. Absolutely nothing is left behind in any system log.
Thanks for your reports. We’ll try and figure out what’s going on.
installation error is
More help is available by typing NET HELPMSG 2185
Unregistering driver
Done
Removing Bins from C:\windows\System32\Drivers
Could Not Fine C:\windows\System32\Drivers\gwdrv.cat
Could Not Fine C:\windows\System32\Drivers\gwdrv.inf
Could Not Fine C:\windows\System32\Drivers\gwdrv.sys
Done
bit.ly/1wfvmPL
bit.ly/14GSrEl
HI
change the location in control panel To UK
Solved it
It was the answer!
But why it must be?
It Worked Tanx,
But Why would it be like this
hi
I’m using windows 7 and i have the same problem , is the problem solved?
i tried to install it from the 360 total security by adding the firewall it gave me
Installation failure! 1.0.63
after that i tried the last version from the website directly and it was the same with the 1.1.27
thanks
We have not seen this error in awhile, but we’ll investigate and try to recreate this. May I ask what language your OS is set to?
The system language is english
Windows 10, 64bit error installing Glassware v1.1.41.
Corrupted installation, extracting freezes at icudt54.dll 40%
Tried another download.
Can you help?
Fixed it.
Re downloaded the same beta version as above using the link at top of this forum page.
Reinstall worked perfect.
THX
its really worked after change my location thx a lot
