K9 Protection Not Being Monitored
I have just started using K9 web protection (http://www1.k9webprotection.com/) and it appears that not all traffic is being measure. Does my system need reconfiguring, is this a know problem or are the 2 products incompatible.
Thanks.
After installing GlassWire we warn that your PC should be rebooted to pick up all network activity, but we don’t force the reboot. Did you reboot after the install? If not please try rebooting and see if it solves the problem.
If K9 Web Protection sends all your traffic through itself then it’s possible GlassWire will not see the traffic because GlassWire can only report what it can see. I haven’t ever heard of K9 before so I’m not sure how it works.
